From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
What else to change out during header install?
Headers are going on Tuesday....got to thinking maybe while the system is apart might be a good time to change out some things. I've seen some posts where it was a good opportunity to put in new O2 sensors, or spark plugs...however, my car runs fine with 50k miles, and the Vette mechanic said it isn't necessary unless I was throwing codes, so whatcha think?
I think it's really up to you. When I installed my headers, I went ahead and did the plugs and wires. Had to remove them anyway, so I decided to re-install new parts. Did not change the sensors, just moved the rears to the front. Also installed the "Koolsox" on the wires. Had the car dynoed and the rear sensors programmed out. My personal opinion is with 55k I would go with new plugs and wires.
