Clutch Master cylinder replacement
Old Sep 27, 2009 | 12:13 AM
z06801's Avatar
z06801
Default Clutch Master cylinder replacement
I am replacing my clutch master cylinder. Is there any reason to buy it with the quick release line on the bottom and the the new reservoir in place. Is it worth the extra $
Old Sep 27, 2009 | 10:18 AM
Ranger's Avatar
Ranger
Master cylinder comes with the reservoir and line to the actuator already attached. Here is a pic of a used complete C6 master. It's very similar in configuration to the C5 version.
Ranger
Old Sep 27, 2009 | 10:27 AM
whitelite's Avatar
whitelite
Ranger
Old Sep 27, 2009 | 12:01 PM
z06801's Avatar
z06801
I have found it also with out the reservoir and bottom line with the quick release like this. this way it is $60-70.00
Old Sep 27, 2009 | 12:08 PM
Ranger's Avatar
Ranger
The master cylinder is the part that most frequently fails. And the entire assembly comes with good junctions and is pre-bled. For $30-$40 "savings" you increase the risk of a leak which may entail trouble-shooting with higher-cost time and inconvenience implications.
Also, be certain that you are getting the latest GM PN for your VIN.
Everything your car does depends on the correct functioning of the clutch hydraulics.
Ranger
Old Sep 27, 2009 | 12:35 PM
z06801's Avatar
z06801
thank you, that answers my? I got the job done to the point of disconnecting the lines. Already had the car on jack stands waiting for wheels from the powder coater. pretty easy diy, Hope it helps.
To Clutch Master cylinder replacement
