Starter Problem?
Old Oct 2, 2009 | 01:27 PM
suncoast1109's Avatar
suncoast1109
2nd Gear
Default Starter Problem?
I have a 2002 C5 w/automatic. With no warning or alarms the car failed to start. There was no clicking of the solenoid or any other noises, just the lights dimming like it was going to ground. I put a battery charger on the battery and made sure it was fully charged and it did the same thing. The car has 60K miles on it. Any ideas would be helpful.
Old Oct 2, 2009 | 01:33 PM
lucky131969's Avatar
lucky131969
Inspect battery cables for corrosion and security. Easiest thing to check without having the car up, is 12 volts at the TDR from the ignition switch.
Old Oct 2, 2009 | 01:40 PM
suncoast1109
2nd Gear
What's a TDR and where is it located?
Old Oct 2, 2009 | 01:52 PM
lucky131969
Good info here, but it depends on your abilities, and if you have a multimeter. I'll PM you my number if you have questions.
http://www.c5help.com/c5_no_start.htm
Old Oct 2, 2009 | 05:58 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Are you hearing the click of the solenoid? If you are, the TDR is probably working.
To Starter Problem?
