So why would a basically stock 2003 C5 lean out?
![](/forums/images/ranks/7k-10k.gif)
Cruise-In IV Veteran
Cruise-In VII Veteran
St. Jude Donor '06
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
2003 vert. Vararam intake and that is about it.
Runs great until you lean on it hard. At about 3500-4000 rpm it starts detonating bad and then it starts backfiring through the intake.
Two different tanks of gas.
Fuel filter getting clogged so it is starving?
Come on experts... help me out.![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![Big Ears](https://www.corvetteforum.com/forums/images/smilies/bigear.gif)
![](/forums/images/ranks/11k.gif)
When is the last time the fuel filter has been changed?
St. Jude Donor '06
Just got the car today and drove it from San Diego to Sacramento. (500 miles)
I haven't looked through the codes yet.
My guess is that the filter has never been changed.
![](/forums/images/ranks/2k-3k.gif)
2003-2004 years are not serviceable fuel filters that are outside of the tank. Its inside the tank and is considered a non serviceable item. You have to pull the tank to access the fuel pump and its parts and its a PITA...
Dirty MAF maybe so id defiantly clean it since it only takes 5 minutes or some water in the gas you got some where, or the lousy winterized higher ethanol % gasoline just hit all the stations here in Ca as well starting last week and will affect all cars with worse gas mileage and worse performance...
3700-4000 is where your MAF takes over full time so I bet its dirty.
![](/forums/images/ranks/1k-2k.gif)
I am having the same issue on my 03 vert. Looked for the fuel filter today and couldn't find it.
I read somewhere that the advanced fuel system without the easily accessible filter came in late 03. And looking in the GM Tech service manual 03 shows the filter replacement procedure and it is deleted for 04.
Mine was built in Dec 2002 so it should be there above the drivers exhaust on the rail, I just don't see it though.
If it's in the tank, I thought there was an access panel to the tank in the left wheel well. Any truth to that?
Here is the thread with all of the stuff I've chased. http://forums.corvetteforum.com/c5-t...-its-guts.html
I kept thinking fuel filter in the back of my head but I really didn't think it had enough miles to need one.
Z06,
If it is in the tank, is it a dealer service? What do you think that might go for?$$$$
Z06,
St. Jude Donor '06
The former owner called me and told me it happened to him before. It is the exhaust check valve. Apparently when they stick they can cause this behavior.
He cleaned it with carb cleaner and WD40 and said it fixed it before.
I ordered a new one today. I just hope it is the easy one on the drivers side and not the one behind the intake (which has to be removed to replace).
Oh, and it has not thrown a single code.
![Crazy](https://www.corvetteforum.com/forums/images/smilies/crazy.gif)
Mine started with a P1415 drivers side air check valve. I replaced it, no dice. That only runs when the car is warming up and then the air pump shuts off. I had mine on a data logger today and once it is warm it was commanded off. I think it's just for emissions and I have read a bunch of posts where people mod their cars and delete it completely. Mine only threw the code in the morning during the first few minutes of driving.
Bill Curlee has a good procedure for cleaning that valve, http://forums.corvetteforum.com/1559066886-post18.html
Z06,
Z06,
Here is how the FSS works and all parts:
http://www.corvetteactioncenter.com/...el+Tank+System
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
I tuned my AIR pump out and took it off completely cause of that code and drivers valve always sticking. No way im pulling the intake to change the stupid valve on drivers side. Too bad GM engineers didnt have enough brains to put the drivers valve easily as accessible as the passenger one.. I left the lines and valves in for smog visual check though but they have no idea nor does their computer tell them its tuned out or pump removed and not working. ![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Z06,
Z06,
![](/forums/images/ranks/4k-5k.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
I'm having basically the same problem with an LS1 that I installed in my C3, check under my sig for the other post as I try and work through it. So far no solution.
Frank
Frank
Did you find it yet?? I took mine to the dealer and they found that the exhaust was restricted. They ordered it under warranty (8 years/80k miles).
You might want to check yours. Just pull the HO2 Sensors one at a time and put a low pressure gauge in its place. They should all read around 2 psi. If the before cat readings are significantly higher on one side or both, you might get a free pipe too!!
The warranty covered all of the diagnostic fees and mechanic time for my 03 Vert.
