MAF conector removal pics
Old Feb 22, 2002 | 11:31 PM
Mike Mercury's Avatar
Mike Mercury
Default MAF connector removal pics
since some have asked.....
These pics are of a 2002; I do not how many C5 years this is good for.
There is a tab that is a part of the removable connector that must be raised away from the MAF plug, then the entire connector easily lifts off.
here is a pic of the end of the removed connector, you can see the tab at the top. There is a foreskin around and hiding the view of this tab when it is attached to the MAF.
I used a bladed screwdriver and was able to reach in to lift up on the tab.
I'm sure GM sells a $25 tool to make this easier... but you know... I am a cheap bastich :)
hope this helps
[Modified by Mike Mercury, 10:44 PM 2/22/2002]
Old Feb 23, 2002 | 05:47 PM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: MAF connector removal pics (Mike Mercury)
