Head Gaskets
Old Oct 3, 2009 | 06:05 PM
2079's Avatar
2079
Default Head Gaskets
I have a 2000 LS1 , I will be installing LS 6 Heads , therefore I will need new head Gaskets.
There are 2 available head gasket ..
97-01 LS-1
02-04 LS-1 & LS-6
Which one do I need ??
These are from Gene Culley GM parts Direct. listing.
Old Oct 3, 2009 | 09:22 PM
donkelso's Avatar
donkelso
Buy the gaskets to match the heads. With LS6 heads you should go with the newer 02+ gaskets.
Old Oct 4, 2009 | 09:17 AM
2079's Avatar
2079
Originally Posted by donkelso
buy the gaskets to match the heads. With ls6 heads you should go with the newer 02+ gaskets.
thank you !
Old Oct 4, 2009 | 09:23 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Either will work, but the later model MLS gaskets are less expensive, and will make for less cleanup work if you ever have the heads off again in the future.
To Head Gaskets
