Front caliper help needed.
Old Oct 3, 2009 | 06:06 PM
markh1977
Default Front caliper help needed.
I need a pic of the inner side of a front caliper installed. I had my calipers powder coated a year ago and i had to remove all the fittings. I'm ready to reinstall them, but i cant remember which fitting go into which hole. I have 4 holes. I know one is for the bleed screw and one hole is for the brake hose. One of the extra holes is on the other piston chamber and the other hole is opposite of the bleed screw hole.
TIA
Old Oct 3, 2009 | 08:53 PM
byronhunter's Avatar
byronhunter
Be better if you post a pix of your caliper.
Sounds like you're describing a C3 caliper.
Old Oct 3, 2009 | 10:13 PM
markh1977
I'll make it easy.
which fiitting(#) goes into which caliper hole(letter)?
Also, which of these will need a washer?
fyi, I am using s.s. hoses i bought from L.A.P.D.
Old Oct 3, 2009 | 10:27 PM
byronhunter
Bleeder #4, upper most hole "C"
Block off "A"
Brake Line on "B"
Block off "D"
By the way, my '02 does not have holes "A" or "D". That calliper could be used on either side.
All need a washer except the bleeder screw.
Old Oct 3, 2009 | 10:47 PM
markh1977
ok, but which fitting is a block off, and which one is for the brake line?
Old Oct 3, 2009 | 10:51 PM
byronhunter
Long one for the brake line!
Old Oct 3, 2009 | 11:29 PM
markh1977
I thought i was making this easy????
a=?
b=1 or 2?
c=4
d=?
Old Oct 3, 2009 | 11:42 PM
byronhunter
A=2
b=1
c=4
d=3
Am I getting graded on this test? You'll let me know if I passed, ok?
Old Oct 4, 2009 | 07:38 PM
markh1977
well find out when i start driving it. thanks for the help.
To Front caliper help needed.
