Accelerator Pedal Positioning Sensor
Old Oct 6, 2009 | 02:34 PM
Rocketman02's Avatar
Rocketman02
Cruising
Default Accelerator Pedal Positioning Sensor
On my 2001 Z06 I continue to get codes PCM-1285 and 1286 they both have a "H C" behind them but they keep popping up i will occationally get reduced power message. I noticed that last night when i was sitting at a stop light in neutral with my foot off he gas pedal the engine would idle up to about 1500 rpm for 3-5 seconds then drop back down the the normal 700rpm or so... So is that a indication of the APP sensor going out if so how much and where can i get one? i need one asap! i live in arkansas thanks for all the help! only other codes im getting is the 1214 and 1278 and i assume that is the EBCM that need to be sent to ABS fixers or someone of that sort...
Old Oct 6, 2009 | 07:33 PM
Rocketman02
Cruising
anyone?
Old Oct 6, 2009 | 08:40 PM
JonLT4CE's Avatar
JonLT4CE
I replaced my ACC pedal a while back. I got it from a salvage yard. I paid $90 for it. I think it was over 300 new.
It takes about 10 minutes to change - very easy.
Old Oct 7, 2009 | 12:34 PM
Rocketman02
Cruising
ok cool deal well if anyone on here has one for sell let me know asap! cause i def need one!
Old Oct 7, 2009 | 12:38 PM
lucky131969's Avatar
lucky131969
Post in the part section........
To Accelerator Pedal Positioning Sensor
