A/c
Old Oct 7, 2009 | 03:46 PM
padojada's Avatar
padojada
Default A/c
A/c colder on the pass side than driver side. Any Ideas???
Old Oct 11, 2009 | 04:40 PM
padojada's Avatar
padojada
Could the vacuum hose for the hvac be the cause for the not so cold driverside air and colder pass side
Old Oct 11, 2009 | 05:13 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I had the same problem, refrigerant was 6 oz. low.
Old Oct 11, 2009 | 07:51 PM
jrose7004's Avatar
jrose7004
The 98 I used to have did that when it needed freon.
Old Oct 11, 2009 | 07:53 PM
Oldvetter's Avatar
Oldvetter
If you have manual A/C, it is low freon.
If you have automatic (dual zone) A/C it could be low freon or actuator problems.
Check freon level first.
Old Oct 11, 2009 | 08:55 PM
padojada's Avatar
padojada
Thanks Guys i'll do that tomorro. Im hoping its just that.
To A/c
