Low voltage codes on ox sensors
Old Oct 8, 2009 | 12:44 PM
soggysailor's Avatar
soggysailor
Default Low voltage codes on ox sensors
I have an occasional issue with a check engine light. When I pull codes I get; 0131,0137,0151,0157. These are low voltage codes for all 4 oxygen sensors. I'm guessing a loose ground? It must be in a connection that all 4 sensors share. The car has a stock exhaust, no headers. Has anyone had an issue like this?
Old Oct 8, 2009 | 01:51 PM
byronhunter's Avatar
byronhunter
Old Oct 8, 2009 | 03:08 PM
lucky131969's Avatar
lucky131969
Nope. As you can see by the diagram, the O2's are all discrete circuits to the PCM. Do you have headers?
Old Oct 8, 2009 | 04:04 PM
soggysailor
No headers......stock exhaust. I'm guessing some kind of connection failure, but I honestly don't have a clue. I doubt all 4 ox sensors are faulty.
Old Oct 8, 2009 | 04:07 PM
MattB's Avatar
MattB
Maybe try cleaning or replacing the fuse. I've had corroded fuses before.
Old Oct 8, 2009 | 09:33 PM
soggysailor
I checked the fuse. It looked clean and checked good with a ohm meter.
To Low voltage codes on ox sensors
