Low Oil Pressure
Old Oct 9, 2009 | 05:31 PM
dberry08's Avatar
dberry08
Default Low Oil Pressure
Hi,
Got a new message today on the DIC when I started the car: Low Oil Pressure, Check Gauges. Sat for 20 seconds and went up to 40PSI. Is this an issue or something that happens if the car sits for a week. Thanks.
Old Oct 9, 2009 | 05:43 PM
lucky131969's Avatar
lucky131969
No.
Old Oct 10, 2009 | 08:49 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Assuming you have the correct oil level in the crankcase, and you are using the correct viscosity oil, a twenty second delay to build oil pressure is unusually long. Even if the car sat for a week, the oil filter anti-drain back valve should prevent this from happening.
Try a new oil filter, if the problem persist, you will have to look elsewhere.
Old Oct 12, 2009 | 01:48 AM
AmMscl's Avatar
AmMscl
Oil pump O ring?
Old Oct 12, 2009 | 04:56 AM
hotmerc's Avatar
hotmerc
Just went through this very same problem with my Suburban. But a GM rep told me to make sure the oil filter I used had a check valve in it. Of course he recomended a GM filter, but there are other filters out there that have them. The NAPA gold filters have them for sure.
Old Oct 12, 2009 | 08:26 PM
dberry08's Avatar
dberry08
Didn't happen the rest of the weekend, we'll see what happens on Friday again...if I can wait that long to drive it
Old Oct 28, 2009 | 12:11 AM
AmMscl's Avatar
AmMscl
Mine was the pressure relief, and it was on borrowed time!!! O ring completely gone.
Old Oct 28, 2009 | 11:43 PM
fnsblum's Avatar
fnsblum
There is no valve of any kind in the PF46 filter. There is a by-pass valve in the filter head/adaptor. The purpose of which is to insure oil flow to the engine if the filter is plugged. Some engines like my Duramax have the by-pass valve in the center bottom of the filter where the oil enters. Later! Frank
Old Oct 29, 2009 | 10:09 AM
dberry08's Avatar
dberry08
it happened one more time, but hasn't happened since. The oil pressure sits around 40 now...
Old Oct 29, 2009 | 10:18 AM
Steve20's Avatar
Steve20
have you switched back and forth between the digital oil pressure reading and the instrument guage, do they read about the same?
Steve
Old Nov 14, 2009 | 07:21 PM
dberry08's Avatar
dberry08
yea the pressure gauge and digital reading are the same...haven't had an issue since.
Old Nov 15, 2009 | 08:32 AM
David426's Avatar
David426
No oil pressure for 20 seconds on a start up?? mine started out like this and was inconsistant,, Maybe 5 seconds of no oil pressure.. Dealership replaced the oil pump asseymbly under warranty at 43k miles.. Bearings were checked too, with no damage, thank God. the problem was not the oil pump itself . It was debris(o-ring) causing the pressure relief valve malfunctions that were intermiitent No oil pressure is a no no All stock-type pumps have a pressure relief valve. This is necessary because cold, thick oil at start-up, or another restriction such as a plugged oil filter, can cause a serious problem.. Debris can also end up in the pressure relief valve, possibly causing pressure to bleed off leading to a low oil pressure situation, perhaps ending up in engine damage
In addition, manufacturers have reported that there appears to be an increase in post rebuild engine failures as a result of the oiling system failing to prime itself. Reports from warranty claims have revealed completely dry oil pumps in some cases... I would be deeply concerned if I were you,however its your car,your money. Just an FYI
Old Nov 15, 2009 | 09:19 AM
David426's Avatar
David426
Sorry, I did not read your post before I posted. You are absolultely correct.. The oil pickup has a screen, however it either gets clogged or smaller debris gets through and colagulates
Old Nov 15, 2009 | 09:54 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Incorrect, the AC DELCO filters like most oil filters does have an anti-drain back valve within the filter housing.
http://www.acdelco.com/parts/filters/oil-filters.jsp
Yes, there is a bypass valve in the filter block which allows oil flow to the gallery when the differential pressure in the filter exceeds a certain amount, the service manual does not say what that setting is.
To Low Oil Pressure
