is there any gain diffrence in for example 90mm, 92mm, 95mm, or maby 100mm. on that setup
which should be the best buy for my?
Baering
Iceland
Since you have a 92mm intake, you need to go with either a 90mm or 92mm TB...anything larger than that, even if you could get it to bolt up, would be a waste and/or hurt performance.
Lots of folks pick up a used LS2 90mm unit, and do some mild port and/or polish work to it. I've also read nothing but good reviews on Nick Williams throttle bodies. Just Google Nick Williams, and you'll find all kinds of information.
I've read that many people have issues with the Fast 90mm TB, more specifically fit and finish issues that cause the throttle blade to stick open at WOT.
Hope this helps.
ok, i see
what about diffrence between polished 90mm, and stock 92mm, are there any performance diffrience there you think?
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
How about putting a vacuum guage or manometer across the throttle body, and measuring the pressure drop across it at WOT? This would give you a baseline, and tell you if an expensive replacement TB is worth it.
Are there any one out there that know , if there are any diffrence there , 90mm vs 92mm on an 92mm FAST
i know allign c5 (Doug)
is running Fast 92mm (opened to 95mm) and an 95mm Xtr.thrb.
