iPod connection
Old Oct 10, 2009 | 09:35 AM
warlock007's Avatar
warlock007
Default iPod connection
Is there anyway to wire up to stock 2000 Bose cd player
Old Oct 10, 2009 | 09:43 AM
lucky131969's Avatar
lucky131969
Yep, great info in the audio section.
Old Oct 10, 2009 | 11:47 AM
warlock007's Avatar
warlock007
Must be blind but don't see any button that says audio. That's why I put in tech section
Old Oct 10, 2009 | 11:51 AM
VET IT B's Avatar
VET IT B
At the top. Click on Form, general then audio.
Old Oct 10, 2009 | 12:14 PM
lucky131969
http://forums.corvetteforum.com/audio-electronics-20/
Old Oct 10, 2009 | 12:27 PM
warlock007's Avatar
warlock007
Thanks guys
Looked up but don't see anything for iPhone 3Gs instructions. Can it be done and can someone move this thread there.
Old Oct 10, 2009 | 02:53 PM
lucky131969
Thanks guys
http://stores.homestead.com/2point5/...OCK/Detail.bok
Old Oct 10, 2009 | 02:58 PM
i2ibud's Avatar
i2ibud
8th Gear
Just installed an iPod2Car with the stock Bose on my 2000 coupe, works great. You'll need the adapter, PXHGM4, remove the plug from the radio and insert the adapter in between, route the iPod docking cable through the console and you're done. I don't have the CD changer, you'll lose it if you do. iPod selected via the AUX button. Depending on the iPod2Car you buy you may also need the newer PODCBLB20-5V docking cable which solves charging problems on newer iPods.
Old Oct 10, 2009 | 11:06 PM
tonmarchelli's Avatar
tonmarchelli
Heres a writeup i did a few months ago. works great for my Iphone and only cost a few bucks and a few hours.
http://forums.corvetteforum.com/c5-g...to-inside.html
Old Oct 11, 2009 | 04:13 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Here is the procedure I wrote with pics on my IPOD install.
http://mysite.verizon.net/res0aae8/ipod.html
Hope this helps !
Toque
Old Oct 11, 2009 | 05:56 PM
warlock007's Avatar
warlock007
does anyone know if the stock single CD player for the 2000 has the cd plug in the back of the radio or the back of the car? dont want to take car apart to just look for that plug.
thanks for everyones input
Old Oct 12, 2009 | 06:33 AM
warlock007's Avatar
warlock007
ttt
Old Oct 12, 2009 | 03:19 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
"does anyone know if the stock single CD player for the 2000 has the cd plug in the back of the radio or the back of the car? dont want to take car apart to just look for that plug.
If you 2000 has the stock single CD player then you are set. All you have to do is unplug the wiring harness in the back of the radio and plug in the special wiring harness that mates to the ipod player. Check the web sites, they list the specifics.
If you have a remote multi CD box in your truck, it will be disabled.
Best of luck,
rr
Old Oct 12, 2009 | 03:40 PM
i2ibud's Avatar
i2ibud
8th Gear
If you have the CD changer it has both. IIRC some cars even have the harness for the changer installed even though the changer is not. If thats the case you have the option (with the correct adapter) to install either way, but you'll lose the changer if you have it. Easiest is as mentioned, in the back of the radio.
Old Oct 12, 2009 | 05:01 PM
miltievette's Avatar
miltievette
Yes it"s behind the radio, that's where you use PHXGM 4 harness.
To iPod connection
