DRL Trouble
Old Oct 10, 2009 | 10:03 AM
VET IT B's Avatar
VET IT B
Default DRL Trouble
I installed clear corners and switchbacks about two years ago. 6 mo. ago I had to remove and replace both left and right side switchbacks. Bulbs were burned out.
Now I getting all sort of weird DRL effects. They come on, go off, sometimes both, sometimes only have one on, they sometimes flicker.
Where do I look? Some sort of short?
Thanks, Mark
Old Oct 10, 2009 | 11:14 AM
lucky131969's Avatar
lucky131969
Thanks, Mark
More like some sort of open. You need to figure out if you are losing power or ground. The multifunction switch is a common offender, but take the time to go through the schematic with a DMM to be sure, before replacing parts.
