I know, dumb question
Old Oct 11, 2009 | 12:36 PM
myquickZ06's Avatar
myquickZ06
Default I know, dumb question
Last month I bought a 2003 coupe with 8k miles on it. The stock engine has been brought up to C5 Z06 specks, heads and cam. Does this make it an LS6?:o
Old Oct 11, 2009 | 01:17 PM
lucky131969's Avatar
lucky131969
Nope.
Old Oct 11, 2009 | 02:32 PM
ALLEGRO's Avatar
ALLEGRO
There are other differences between the LS1 and LS6. Probably the biggest difference is inside the block milling. In addition there are different pistons, valves and even ECU mapping.
Old Oct 11, 2009 | 07:49 PM
jrose7004's Avatar
jrose7004
No it wouldn't make it a LS6.
Old Oct 11, 2009 | 09:23 PM
intoc6s's Avatar
intoc6s
It doesn t take very many mods to a LS1 to make LS6 HP.(or alot more) But, like stated b4, its not technically a LS6.(Even with LS6 heads, camshaft and tune etc.)
Old Oct 11, 2009 | 11:31 PM
C5Natie's Avatar
C5Natie
I thought all LS1 vettes 2002-2004 had LS6 blocks and intakes, the only differences being the heads and cam? Right or wrong? Obviously all the ecu stuff would have a different tune but that can easily be changed. Correct me if Im wrong guys, not sure.
Old Oct 13, 2009 | 06:33 PM
myquickZ06's Avatar
myquickZ06
That's what I was told too. The changes made to my engine were factory certified, making it a Z06 engine. Is a C5 Z06 an LS6 or not?
Old Oct 13, 2009 | 06:56 PM
David426's Avatar
David426
Factory certified? Did the factory send you another VIN plate for the block? I don't think so.. Maybe I'm missing something here
Old Oct 13, 2009 | 07:13 PM
myquickZ06's Avatar
myquickZ06
The vin plate still says it's an the original LS1. The factory only certifies that it is a modified LS1 brought up to LS6 specs. Or C5 Z06 specs.
To I know, dumb question
