C5 brake hints
Old Feb 24, 2002 | 10:11 AM
Tom Piper's Avatar
Tom Piper
Default C5 brake hints
Soon I will have Z06 C5 front brakes on my C4.
Since my shop manuals are for the '92 C4, I don't have any information on the C5 brakes. What hints can you C5 guys give me on the C5 front brakes -- any tricks will be appreciated. I think I saw a post saying the torque specs for the caliper bracket bolts are 125 lb-ft and the caliper bolts are 23 lb-ft.
Is there anything else I should know???
Tom Piper
Old Feb 24, 2002 | 10:58 AM
adamsocb's Avatar
adamsocb
Default Re: C5 brake hints (Tom Piper)
On a C5 the caliper bracket bolt torque is 150 ft-lbs. They have friction set glue on them (similar to cement coated nails) that makes them very hard to remove. I had to use a heavy duty impact wrench to get them out. The shop manual says they must be replaced with new bolts because of the glue. The new bolts are $8.00 each and the dealers in my area don't stock them, so I chose to re-use the old ones with Locktite Red high strength thread locker compound. I don't know how they fit on a C4.
On hint:
Put a couple of lug nuts on the rotor to keep it from moving around while you are working on the caliper.
Old Feb 24, 2002 | 06:16 PM
l2vette's Avatar
l2vette
Default Re: C5 brake hints (adamsocb)
The correct torque is 125 ft. lbs. on the caliper bracket bolts and the blue medium strength Locktite will work just fine on the bolts as well.
To C5 brake hints
