Code p0492
Old Oct 13, 2009 | 07:48 PM
zackyam's Avatar
zackyam
1st Gear
Default Code p0492
I am hoping for some help here. On my 2004 ZO6 the check engine light came on today. It showed a code P0492 Where should I look for this problem or can I get some information on this. It says Secondary air injection system insufficient flow bank 2. What should I do? Thanks
Old Oct 13, 2009 | 08:29 PM
padojada's Avatar
padojada
This helped me out alot. One of the member s on this site gave me this info. Hope it works out for you.
one of several sources on the interweb. welcome aboard.
http://www.c5forum.com/ayc/dtcdic.php
Old Aug 1, 2014 | 12:33 PM
Cjwisbroke's Avatar
Cjwisbroke
1st Gear
Default C5 - Smog issues - P0492
I have an 04 Commemorative Edition and fought that code as well. Someone on this site suggested to open the hose that feeds air to the check valves and put carb and choke cleaner in and force with compressed air, then do the same with WD-40 to clean up and free up the check valves. Passenger valve is a nightmare to change (no idea why GM decided to put it there) Started car and white smoke came out of all 4 tail pipes for a while. Took it for a nice high RPM cruise and then had it smogged a few days later. Passed with flying colors!
To Code p0492
