Front Left Turn Signal Not working
Old Oct 14, 2009 | 11:49 AM
Vett-a-matic's Avatar
Vett-a-matic
Default Front Left Turn Signal Not working
I know, i know, i have searched and read most articles on this forum about the front left turn signal, and cannot find one that has exactly the same problem.
My front left turn signal/running light sometimes works intermittently.
More now than ever, in fact i cant get it too work anymore
I saw that some people say its the hazard switch.
When i activate the hazards the front left still does not work.
I sprayed electronic cleaner in the turn signal switch and it started working for a a day again.
then it went back to not working.
So i removed the turn signal switch completely, spraying the contacts in the switch.
DAM thing worked great, every time i checked it, but you know as soon as i installed the last steering wheel cover bolt, sure as ****, the dam thing stopped working.
To me this seems like a faulty turn signal switch and not the hazard switch.
If i buy the richards eliminator deal, isnt that to by pass the hazards?
Will that fix my problem?
Should i just buy or find another turn signal switch?
Old Oct 14, 2009 | 11:59 AM
byronhunter's Avatar
byronhunter
If your Right Turn Signal is working properly, it's not the flasher.
Old Oct 14, 2009 | 12:03 PM
byronhunter
I posted a schematic in this thread, might want to check it out!
http://forums.corvetteforum.com/c5-t...-help-bad.html
To Front Left Turn Signal Not working
