Help with engine and fuel related issues
The previous owner removed a sound system and had a lot of wiring throughout the dash. I started removing wiring thinking that it was for the previous sound system. Anyways, here is were my problem starts. I noticed that he has a kenne bell boost a pump installed. With a little research I found that it is suppose to have a little controller that goes with it. I did noticed that there was some velcro strips underneath the dash and thats were the controller probably was.
My question is, do I still need this bap if I will not be going with a supercharger. I do not plan on any FI and just plan to run the engine N/A as it as a 383 stroker. Should I find a BAP controller and install it or should I remove the BAP all together as it will not be nessesary for the engine without boost.
I've attached a picture of the BAP. It has a few wires going from it. One is a ground then another goes to the brake booster then another two wires are spliced into a gray wire which looks to be OEM. Does anybody know what this gray wire is?
How would I find out which wires under the dash were used for the BAP controller? Maybe someone has instructions which they can e-mail me so I can maybe try to find which wires are which.
I havn't started the engine yet as Im waiting on a tensioner as well as a belt. Should i also be concerned about the stock fuel rail and injectors on the car with this engine and setup? Any help is greatly appreciated.
I would contact Jeff over at TPE about the KB Boost a Pump as he's and authorized dealer and would know what to do.
I know that I will have to have it towed to a local shop and have them go over everything and tune it as it no longer has the supercharger.
