Gear ratio question
Old Oct 18, 2009 | 11:23 AM
devilchrono's Avatar
devilchrono
Default Gear ratio question
I'm trying to figure out the gear ration in my 02' A4 coupe. It's got stock wheels on it with the factory tire sizes, and on the highway in O/D, I'm cruising at 1700 at 70mph. Any help in figuring this out is greatly appreciated.
Old Oct 18, 2009 | 01:59 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Should on a metal tag connected to one of the rear housing bolts--also i've seem some that are etched into the rear end too---i would guess that with 1700 @ 70 MPH you have 2.73's which are stock--The 3.15 gears wear an option --called the "sport gears"---3.42's were not availiable stock on an A4-------
Old Oct 18, 2009 | 09:51 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Gear chart attached
http://i653.photobucket.com/albums/u...raph-MPH-1.jpg
Old Oct 18, 2009 | 11:01 PM
ALLEGRO's Avatar
ALLEGRO
Originally Posted by alxltd1
Good graph.
Old Oct 18, 2009 | 11:19 PM
Double G's Avatar
Double G
Old Oct 19, 2009 | 09:11 AM
65GGvert's Avatar
65GGvert
Or you could look at the code on the glove box door. GU2 is 2:73, G90 is 3:15, G92 is 3:15 "performance axle"
If you put your car in '3", not 'd', and drive 75 mph, you get your ratio. Example: 2173 rpm (appr) is 2:73, 3150 rpm you have 3:15, etc.
Old Oct 19, 2009 | 09:37 AM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/ratio.htm
Old Oct 19, 2009 | 11:22 AM
devilchrono
Thanks for all the helpful advice guys! I'll be sure to look at the tag in the glove box after work today
To Gear ratio question
