'99 Vert ABS issue
Old Oct 25, 2009 | 04:40 PM
srl99's Avatar
srl99
Default '99 Vert ABS issue
My '99 vert has gone from sometimes having the ABS/Traction Control lights on to having them on before getting to the end of the street.
Codes are C1222, C1226, C1233 all related to the right front wheel signal. I have checked continuity all the way up to connector C148 pins G and H. It is always good leading me to believe the module itself has bought the farm.
I have removed it and was going to do a little component level trouble shooting but can't get the board out. Removing the two Torx screws doesn't do it.
So.. has anybody had the board out of one of these?
Failing that, does anybody fix these? Most companies specify 2001 and up.
Is there a place to get a replacement at a reasonable cost?
Thanks.
Old Oct 27, 2009 | 10:03 AM
srl99's Avatar
srl99
