underdrive pully question
Old Feb 25, 2002 | 06:11 PM
abraham's Avatar
abraham
Default underdrive pully question
Will I have any problems with a under drive pully if I have a amp in my car. I didnt even think about that but someone today told me I might have a problem. Whats the scoop?
Old Feb 25, 2002 | 07:16 PM
6Speeder's Avatar
6Speeder
Default Re: underdrive pully question (abraham)
The issue is, at idle, the underdrive pulleys may not provide enough current to drive high demand stereo amps. I have the UD pulleys, and tested with the stock stereo on high, A/C on high, lights and fog lights on, and had no problem, but the stock Bose is, perhaps, power challenged, shall we say? Good luck. :chevy
Old Feb 26, 2002 | 07:15 AM
abraham's Avatar
abraham
Anyone else have any experience with this? Should I not put it on?
Old Feb 26, 2002 | 07:23 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
No problems here, and have a V12 amp, not even battery Cap yet either. If you get a 3 peice, the Alt pully should be smaller, spinning it faster, so your not underdriving it by much.
Old Feb 26, 2002 | 01:53 PM
jmX's Avatar
jmX
Default Re: underdrive pully question (Buckmaster)
I had no problems and I had 2 aftermarket amps in use.
Old Feb 26, 2002 | 02:01 PM
C54TIM's Avatar
C54TIM
I've never had a problem!
Tim
Old Feb 26, 2002 | 02:53 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: underdrive pully question (C54TIM)
There doesn't seem to be any issues with the UDP, except for the tedious install.
My gauges read between 13.9-14.5 volts.
There is a seperate issue with lights dimming when accesories are used (mainly with the HVAC system on) but that happens in cars without pulleys too.
To underdrive pully question
