Help me decide!!!
Old Oct 26, 2009 | 04:42 PM
Venomized03's Avatar
Venomized03
Default Help me decide!!!
I am in the process of rebuilding my transmission right now. I obviously have the rear out also. Should I do some upgrades to the rear while its out? I am pushing over 760rwhp. Thing is, is that I have heard different sides to the story. I have heard that the brace and upgrading the output shafts are a must. On the other hand, I have heard that when you do that, its putting more stress on the other more expensive parts. Basically that if its stock, the first thing to give will be the output shaft. Easy and inexpensive compared to the case or whatever!!! Please help me out here on your guys' suggestions, but hopefully your experience.
THANKS IN ADVANCE
JASON
Old Oct 26, 2009 | 04:49 PM
lucky131969's Avatar
lucky131969
THANKS IN ADVANCE
JASON
Depending on how you drive the car, ,and what tires you are running, you are on borrowed time with a stock rear end.....and 760 RWHP...
Old Oct 27, 2009 | 08:47 AM
Venomized03
Well I know that, lol.. I just want to know if its going to be worth dumping all types of money into the rear, when it will still break. I've heard that when you upgrade the shafts, that they wont really break anymore but that puts more stress on other parts. I'd rather just replace a stock shaft every so often then risk splitting the case or trans ect... Just let the weakest link break
Old Oct 27, 2009 | 12:12 PM
lucky131969
Again, it comes down to how you are going to drive the car, and how effectively you can hook. Breaking a differential case, and breaking an output shaft can go hand and hand. They do not always snap clean. An output shaft can take out the diff case, and if the crack is substantial enough, and the case separates, it can in turn take out the output shaft of the tranny.
Since you have a manual, running the much RWHP without upgrading the differential, just doesn't make any sense.
Good luck.
To Help me decide!!!
