Airbridge question
Old Oct 27, 2009 | 05:31 PM
11sec_C5Z51's Avatar
11sec_C5Z51
Default Airbridge question
on an NA motor, would a custom cylindrical airbridge outperform the typical non-cylindrical airbridges on the market??
Old Oct 27, 2009 | 06:16 PM
lucky131969's Avatar
lucky131969
The claim from most of the air bridge vendors is their design achieves laminar air flow(non-turbulent). The stock accordion air bridge is not smooth inside, so the thought is the air will be more turbulent passing through it. The aftermarket styles are smooth, and while they will be less turbulent than stock, achieving laminar flow of a fluid requires a minimum distance....which is not likely to be achieved in such a short distance that the air travels through the air bridge.
Any differences in flow, as related to the geometry of the air bridge( cylindrical v/s elliptical) would most likely be realized on a flow bench, as opposed to SOTP.
Old Oct 27, 2009 | 06:18 PM
zeevette's Avatar
zeevette
In other word, no.
Old Oct 27, 2009 | 07:00 PM
11sec_C5Z51
So the only reason they use a cylindrical airbridges on boosted applications is because it can hold boost, unlike the the plastic elliptical airbridges that spilt at the seams under boost and not just to increase more air in the airbridge. is this correct??
Old Oct 27, 2009 | 07:13 PM
lucky131969
Yep, the factory ones are not made for boost.
Old Mar 14, 2010 | 03:01 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
I've been looking at adding a 4in cylindrical airbridge (TB to Vararam) also to replace my Vram powerduct.
Old Mar 14, 2010 | 03:38 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Fluid dynamics says no. If you want to maximize flow around a bend, you have to increase cross sectional area within the bend to allow it to flow as well as what the straight tube is capable of.
In other words, a straight pc. of tube bent into an elbow presents a restriction.
Old Mar 14, 2010 | 06:43 PM
Mtlfusion's Avatar
Mtlfusion
So if i have a blackwing, x-pipe and straight exhaust (no lt headers), it is a waste of money to install a VR powerduct?
I'm about to buy one, should I hold out and keep my money for headers?
Old Mar 14, 2010 | 11:03 PM
MPM IV's Avatar
MPM IV
Yes. I'm at 600rwhp on the stock air bridge. I will eventually pick up a carbon fiber one, but only for looks.
Old Mar 14, 2010 | 11:33 PM
Mtlfusion's Avatar
Mtlfusion
Thanks for the moneysaving advice!
Old Mar 15, 2010 | 09:36 AM
All_Motor_C5LS6
So a TB to IC pipe like this http://www.dragtimes.com/images/6432...t-Corvette.jpg won't add any performance gains over a Vararam power duct, if it were going from the TB to Vararam on an NA setup?
To Airbridge question
