failed oil pressure sender
Old Oct 27, 2009 | 10:49 PM
guido7834's Avatar
guido7834
Default failed oil pressure sender
I have the above mentioned dreaded situation on my 2002. the gauge is pegged at 130psi. How urgent, if at all is it necessary to replace. It is not raced, just a weekend cruiser.
Old Oct 27, 2009 | 10:53 PM
lucky131969's Avatar
lucky131969
No biggie.....provided you don't mind not knowing what your oil pressure is.
Old Oct 27, 2009 | 10:54 PM
frc99c5's Avatar
frc99c5
dont cheap out on it, i think its very important.. your oil pump goes out your motors fried..all for saving $30 on a sensor..
easy 3 or so hour project and $30 cost
http://forums.corvetteforum.com/c5-t...placement.html
Old Oct 28, 2009 | 01:15 AM
guido7834's Avatar
guido7834
Anyone know the part number and where to get it?
Old Oct 28, 2009 | 07:03 AM
Tigershark3's Avatar
Tigershark3
From what I could gather from other forum members get the brass one made by Borg Warner - Not sure on the part number but do a search in Tech. Avoid the aluminum unit as I've been told they can fail easily. I'm in the same boat as you - OP pegged. I've got the replacement sender sitting on my workbench but I'm waiting for a crappy weather weekend to put it in. Got mine from Autozone.
Old Oct 28, 2009 | 09:02 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
BWD S4202 from Advance Auto Parts
Make sure it's brass before you buy it! Some old stock sensors on the shelf might still be aluminum.
Old Oct 28, 2009 | 09:13 AM
SaberD's Avatar
SaberD
after having removed the manifold a couple times, it becomes a 30 minute job.
Old Oct 28, 2009 | 10:36 AM
padojada's Avatar
padojada
Ask them to see it first. Do Not Buy the aluminum one. Bwd from advance.
Also imo you should change the sensor the old fashioned way so you can clean out all that gunk under the intake and clean out the knock sensor area. Its worth the extra work in my book.
Old Oct 28, 2009 | 12:22 PM
Quicksilver Vert 01
Cutting a hole in the cowl, to reach the sensor, falls way below my standards of professional work.
Old Oct 28, 2009 | 12:38 PM
guido7834's Avatar
guido7834
I don't think I have the know-how to tackle taking the intake off. Best left to a pto. What would the job cost to have it done?
Old Oct 28, 2009 | 12:39 PM
guido7834's Avatar
guido7834
I meant to write to a pro.
thanks
Old Oct 28, 2009 | 12:42 PM
lucky131969
ECS should be less than an hour from you. Why not give them a call and see what they can do for you?
Old Oct 28, 2009 | 12:49 PM
guido7834's Avatar
guido7834
What is ECS?
Old Oct 28, 2009 | 12:51 PM
padojada's Avatar
padojada
The labor for replacing oil sender is 2.1 hrs so depending on the shops labor rate is how much you will have to pay. Buy the oil sender from advance should be around $35 to $45 and maybe $150 for labor. Hope this helps.
MAKE SURE ITS A BRASS one
Old Oct 28, 2009 | 12:54 PM
guido7834's Avatar
guido7834
Thank you!
Old Oct 28, 2009 | 12:56 PM
lucky131969
What is ECS?
http://www.eastcoastsupercharging.com/
Old Oct 30, 2009 | 11:29 PM
marc5's Avatar
marc5
noticed the same problem with my 2002 this morning, called the dealer and they qouted me 375 to 500 depending on how bad it is, though i specified 'just replace the sender'...
To failed oil pressure sender
Old Oct 30, 2009 | 11:37 PM
padojada's Avatar
padojada
The labor for the job calls for 2.1hrs @ maybe 75 /hr so $150 + 40 for the oil sending unit roughly $200+ tax of course. Tell the dealer all u want changed is the oil sender unit only and it takes 2.1 hrs for the job per motoralldata why the $300 to 500 price? Should be 200 with parts.
Now if you do it yourself its free all you need is the part .
Good luck
Old Oct 31, 2009 | 12:39 AM
marc5's Avatar
marc5
i think just bear the brunt of paying the labor of relocating it... but have to get this product first, check this link...
http://www.totalperformanceengineeri...roducts_id=840
....then you can DIY easily the next time sender fails
Old Oct 31, 2009 | 03:33 AM
LoneStarFRC's Avatar
LoneStarFRC
Brass is good but don't get too obssessed with getting a brass unit instead of an aluminum unit. My aluminum unit is now 2 years old with no worries. Of course I also have the stainless-hose-oil-sender-relocate mod too. If mine ever does fail in the future, all I have to do is pop the driver's side engine trimcover off and there it is; right next to the ignition coils.
