Worth it to upgrade Sway Bars?
Old Feb 26, 2002 | 04:42 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default Worth it to upgrade Sway Bars?
From base 98 vette suspention to either z51, or maybe an after market unit, if so, which one? Will this be a mod I can feel under "spirited" driving :D I'm wanting to know what would help a base vette handle closer or better compared to an optioned one without to much $$$.
Also, why are all the aftermarket z06 wheels crome, any one sell the with the regular OEM finish? What street drag radials are available for the zo6 wide rear tire size?
Old Feb 26, 2002 | 05:53 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: Worth it to upgrade Sway Bars? (TexCorvette)
I upgraded my ´98 coupe/F45 with Y2K Z51 sway bars and I can tell you: it was one of the most effective mods I have done. Still comfort on straight driving and much more fun when cornering because the car really doesn´t roll so much as before.
Frederik
Old Feb 26, 2002 | 07:21 AM
TexCorvette
Default Re: Worth it to upgrade Sway Bars? (C5 Frederik)
cool, how much and where did you get them?
Old Feb 26, 2002 | 07:52 AM
C5 Frederik
Got them from my local GM dealer but do not ask me for the price (it was paid by someone else :D )
Frederik
Old Feb 26, 2002 | 08:06 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
It helped my handling alot I think. :smash:
Old Feb 26, 2002 | 08:47 AM
SNW Vette's Avatar
SNW Vette
Hi, you can get'm from Bob @ Fichtner Chevy.
Steve
Z51 Front Stab Bar $ 117.62
Z51 Rear Stab Bar $ 60.35
Z51 Front Metal Links $ 90.34
Z51 Front Bar Bushings $ 11.60
Z51 Rear Bar Bushings $ 18.52
Z51 Package Total $ 298.43
http://forums.corvetteforum.com/zerothread?id=243106
Old Feb 26, 2002 | 09:43 AM
RyanC7's Avatar
RyanC7
Default Re: Worth it to upgrade Sway Bars? (SNW Vette)
So how about the Z06 kit? Its that any better or about the same as the Z51? I am looking at upgrading since I got the stock FE1 as well....
:seeya
Old Feb 26, 2002 | 11:26 AM
dcronkhite's Avatar
dcronkhite
Default Re: Worth it to upgrade Sway Bars? (Ryan2002C5)
I went with the Z06 sway bars myself. The difference over the base suspension was HUGE. Ride quality for normal driving is unchanged, but throw the car into a hard corner and the difference is immediately noticable and impressive.
Best mod there is for base C5's in my opinion.
Old Feb 26, 2002 | 11:48 AM
GR8-LIFE's Avatar
GR8-LIFE
There is a huge diference in the Z51 suspension to the standard base suspension. I knew this when I took several test drives back when I bought my '99. I do plan on going with the Bilstein shocks but the main reason for this is because I'm lowering the car. I've also been in a car with it lowered and teh billsteins and I was impresssed at High Speed handling compared to my car. So it can be concluded without a doubut, as far as I'm concerend, that the Z51 along with the Bilsteins will definitively yields some sigificant perf improvement and if you get rid of teh runcraps you'll ahve a totally different car from what I hear.
However, I don't know about Z06 (or Hotchkis) sways in the front (the rears are the same). Sure, the Z06 handles better than the non-z06 but that may be attributed mostly to the different tires. The fact is I hear mixed versions of how much of a significant difference front sways are, atleast for street use.
There are also posts on Hotchkis sways which some feel are better than the Z06. However, there have also been posts concerning noises that the Hotchkis makes so I would do more research on this if I were you.
The performance of front sways may play a greater role for track or autocrossing but I have to get into one and see for myself before I buy them.
Old Feb 26, 2002 | 02:57 PM
crocker's Avatar
crocker
I upgraded a 2001 coupe with the base suspension to Z06 front and rear sway bars including new metal links. It's like riding in a total different car. One of the best upgrades I ever did!!!!!
Old Feb 26, 2002 | 03:05 PM
TexCorvette
Default Re: Worth it to upgrade Sway Bars? (Ha-Ha)
thanks for all the great info, and Z51 Package Total $ 298.43 sounds great? How much was this option when bought with the car!? If its less then that, not sur why anyone wouldn't want it!
Old Feb 26, 2002 | 03:12 PM
GR8-LIFE's Avatar
GR8-LIFE
I think it was either $350 or $500. Its all relative, though because, I received a $1500 discount off of MSRP. That was back in mid '98 when C5's were low in supply and high in demand. Nowadays, $1500 off MSRP is nothing as many have done much better than this.
Old Feb 26, 2002 | 03:17 PM
YellaFella's Avatar
YellaFella
Put Z-51 bars on my base package.. it's a great MOD, a "must do" if you ask me. :cheers:
FarmerBob2001's Avatar
FarmerBob2001
Can you add the Z51 package to the F45 suspension? Would there be any benefit to doing it?
Old Feb 26, 2002 | 03:20 PM
Face's Avatar
Face
One word of advice, don't try this alone in the driveway without ramps! It took me a over a hour to get the front one on because there's no ground clearance, I didn't have any help.
Old Feb 26, 2002 | 03:27 PM
TexCorvette
Default Re: Worth it to upgrade Sway Bars? (BLOWNGS)
Now I'm not sure if I should go z51, or z06?
Old Feb 26, 2002 | 06:13 PM
barryscott's Avatar
barryscott
Hey Now:
Go with the Z06 package from Ken, about the same cost, plus the front sway bar is a little larger. I have a 2001 coupe with the base suspension and went with the Z06 bars and Bilstein Sport shocks, great mod. Large improvement in ride and handling. :cheers: :yesnod:
To Worth it to upgrade Sway Bars?
Old Feb 26, 2002 | 10:34 PM
DraftMe's Avatar
DraftMe
Default Re: Worth it to upgrade Sway Bars? (barryscott)
T1 :D My car handles like it's on rails, and I can barely feel the difference in the ride. :cheers:
Old Feb 26, 2002 | 10:49 PM
turboo2u's Avatar
turboo2u
There is a noticeable difference between the Z-51 setup and the Hotchkiss setup. The Hotchkiss bars offer so much roll resistance that they start to overwhelm the tires. (in my case, Nitto 555's). And they cost twice as much. If you push your car VERY hard, go with the Hotchkiss, if not, the Z-51 setup should be adequate. ;)
Old Feb 27, 2002 | 02:12 AM
TexCorvette
Default Re: Worth it to upgrade Sway Bars? (turboo2u)
From ken? This site or the link provided above for the z51 for about $300? I mean if they are the same price, might as well go z06 I would think?
