A/C O-Ring Source
Old Nov 2, 2009 | 03:38 PM
Pie R Squared's Avatar
Pie R Squared
Default A/C O-Ring Source
I replaced my A/C Compressor on the 2001, following RoccoC5’s procedure but I can not seem to find a source for the black o-rings, there was a total of five o-rings in (2) large and (3) small. My local Kragen and AutoZone only sell the green o-rings should I be using these instead of the black ones?
Old Nov 2, 2009 | 05:01 PM
timemender's Avatar
timemender
As long as the new o-rings are the correct size and are compatible with the (R-134a) refrigerant you’re good to go.
Old Nov 4, 2009 | 01:57 PM
jedblanks's Avatar
jedblanks
Green ones should be fine.
Old Nov 4, 2009 | 02:07 PM
lucky131969's Avatar
lucky131969
Do a search. Someone posted the part numbers for the o-rings a while back .
Old Nov 4, 2009 | 11:31 PM
Pie R Squared
I found this posted by Quicksilver Vert 01
1997-2002 Corvette A/C dryer o-ring, inlet and outlet: P/N 52454646
I am thinking these are the smaller o-rings. Anyone have the P/N for the larger ones, it would be the size coming out of the bottom of the condenser.
To A/C O-Ring Source
