High Speed Vibration experience
Old Nov 2, 2009 | 08:03 PM
02KillerZ's Avatar
02KillerZ
Default High Speed Vibration experience
Just wanted to post up my experience with a vibration that I was having over 80mph. Long story short, I balanced the wheels and replaced a bent wheel....the vibration was still there. Noticed there was uneven wear on the tire that was on the bent rim, so I replaced the shocks (car has 75k miles)....vibration still there. Got the car up in the air, I was able to wiggle the rear wheels back and forth, so I replaced the tie rods...BINGO! No more vibration. So for those who have a vibration and can't figure it out, check the tie rods first!
Old Nov 3, 2009 | 06:54 PM
98turbls1's Avatar
98turbls1
I have the same thing in my Z06. It happens exactly at 80mph. It shakes like it's coming apart. Good find. What did you end up replacing them with?
Old Nov 4, 2009 | 12:03 AM
02KillerZ's Avatar
02KillerZ
That's what my car felt like, it's not just a vibration in the steering wheel, but the whole car. The tie rods were about $80 each from the dealership. Not a hard job, just make sure to get an alignment afterwards. I replaced the shocks with Bilstein Sports.
Old Nov 4, 2009 | 10:49 AM
98turbls1's Avatar
98turbls1
So it was just the back ones? Yeah my whole car shakes. That's what has baffled me, if it was just the sterring wheel it would have been easier to diagnose.
Old Nov 4, 2009 | 02:44 PM
02KillerZ's Avatar
02KillerZ
Yes, just the tie rods in the back. To check them jack up the car and try to wiggle the wheel back and forth with your hands at 9 and 3. If it moves at all, they are worn. With the new tie rods, it's rock solid, no movement.
Old Nov 4, 2020 | 05:38 PM
sleddrvr's Avatar
sleddrvr
This just saved me a bunch of money!! I was about to go crazy trying to figure out what was causing the vibration. I can move my passenger side back wheel.
Thanks!!
Old Nov 5, 2020 | 11:35 AM
02KillerZ's Avatar
02KillerZ
Thanks!!
I hope you get it sorted out! It took me weeks to figure out that the vibration was coming from the tie rods.
Old Nov 5, 2020 | 03:12 PM
Great find on the source of the vibration. Moving this over to C5 Tech.
Old Nov 9, 2020 | 11:33 AM
schmuckingham's Avatar
schmuckingham
is it like a pulse through the whole car? Mine has this pulse that starts around 75 and gets worse with speed.
Old Nov 9, 2020 | 03:21 PM
sleddrvr's Avatar
sleddrvr
That is it. It was my right rear tie rod. Swapped them for the Baer tie rod ends and it fixed the issue. Had to have it aligned of course.
Old Nov 9, 2020 | 03:27 PM
schmuckingham
The Baer one use a heim joint?
Old Nov 9, 2020 | 07:35 PM
sleddrvr's Avatar
sleddrvr
Yep
Old Nov 9, 2020 | 11:41 PM
29speedster's Avatar
29speedster
Just bought a 03 Z06 and drove it 800 miles to get it home. Has this same 80+ mph vibration - sure enough thanks to you, I jacked it up and it has some movement on both rear wheels.
Thanks for the share of info!
To High Speed Vibration experience
