S.S. Brakelines
Old Feb 26, 2002 | 05:10 PM
l2vette's Avatar
l2vette
Default S.S. Brakelines
Does anyone have any experience with stainless steel brake lines?? I have a set of Goodrich lines and I am wondering if the fit and clearances will be any problem.
Thanks! :confused:
Old Feb 26, 2002 | 05:58 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: S.S. Brakelines (l2vette)
I have goodridge lines on my car, I have had np problems with them. :)
vetterdstr :cheers:
Old Feb 26, 2002 | 06:13 PM
HIGHRPM's Avatar
HIGHRPM
Default Re: S.S. Brakelines (vetterdstr)
I have DRM stainless lines on my car.....I keep getting c1225 codes every time I drive more than a few miles....The dealer said this is common, it seems that the steel lines interfere with the wheel speed sensors......anyone else have this problem or know of a solution
Old Feb 26, 2002 | 07:56 PM
raymond8pistons's Avatar
raymond8pistons
I have the Goodrich lines on my 2000 FRC. No problems at all. Just be careful with where the lines are located . The Goodrich lines are slightly longer than stock, and I was careful with how the line ran between the caliper and the connector on the wheel well. Otherwise it is straight forward.
Old Feb 26, 2002 | 08:43 PM
l2vette's Avatar
l2vette
Default Re: S.S. Brakelines (HIGHRPM)
Interesting, do you think the ss line interfere with the transmitter on the wheel tire pressure sensors? :eek:
Old Feb 26, 2002 | 09:15 PM
vetterdstr's Avatar
vetterdstr
I had the Russell brake SS lines and it threw codes all day long. I took it to the dealership and after extensive parts replacing, & phone calls. They found that the ground on the SS brake line was bad. I know this sounds stupid but... if the SS brake lines are not grounded properly they will interfere with the Wheel speed sensors and you will get codes/ AH, ABS & TC will shut off while driving the car.
When I switched to the Goodridge lines... the 4 month ordeal conserning the codes and :bs were instantly gone!! :yesnod:
vetterdstr :cheers:
[Modified by vetterdstr, 5:16 PM 2/26/2002]
Old Feb 26, 2002 | 10:45 PM
C54TIM's Avatar
C54TIM
I have them on my car, never had a problem!
Old Feb 27, 2002 | 12:38 AM
l2vette's Avatar
l2vette
Default Re: S.S. Brakelines (C54TIM)
How is the fit with the F45 suspension?
Old Feb 27, 2002 | 01:09 AM
vetterdstr's Avatar
vetterdstr
no problem with the F45 shocks
vetterdstr :chevy
Old Feb 27, 2002 | 01:42 AM
mfrnka's Avatar
mfrnka
I've got F45 and the Goodrich lines. No problems. Both the front and rear Goodrich lines are longer than stock. However, make sure the longer lines go on the rear.
Old Feb 27, 2002 | 02:30 PM
l2vette's Avatar
l2vette
Default Re: S.S. Brakelines (mfrnka)
Thanks for tip! :cheers:
Old Feb 27, 2002 | 02:36 PM
Gary2KC5's Avatar
Gary2KC5
I have the Goodrich and the only issue is that there is a tad of drag when turned full lock. Otherwise no issues and no codes.
I saw some other posts about 6 months ago that claimed other lines had to be demagnatized before installing.
Make sure you have the new copper washers before installing. Mine were missing and I had to go to the local part store in the middle of the install.
Old Feb 27, 2002 | 02:43 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
I have the Goodridge lines with no problems at all.
Old Feb 27, 2002 | 06:04 PM
HIGHRPM's Avatar
HIGHRPM
Where did you buy the Goodrich SS brake lines?? I'm going to replace my DRM's....I really tired of throwing codes all the time
Old Feb 27, 2002 | 06:26 PM
vetterdstr's Avatar
vetterdstr
West Coast has the Goodridge for $129
vetterdstr :cheers:
Old Feb 27, 2002 | 11:12 PM
l2vette's Avatar
l2vette
I got the Goodrich G-Stop SS brakelines from West Coast Corvettes. Still WAITING for the Calipers to arrive!! :mad
To S.S. Brakelines
