Recalibrated MAT sensor
Old Feb 26, 2002 | 07:02 PM
gbm's Avatar
gbm
Default Recalibrated MAT sensor
I'm seeing conflicting info on this; if you have a 99 or newer, I've seen that it doesn't do anything for you, only older vehicles.
True or BS?
Thanks!!! :confused:
Old Feb 26, 2002 | 09:32 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Recalibrated MAT sensor (gbm)
Dont get it... waste of money and it does not help your car... In Fact it hurt my car thats why I took it off and tossed it! :smash:
vetterdstr :cheers:
Old Feb 26, 2002 | 10:34 PM
gbm's Avatar
gbm
Default Re: Recalibrated MAT sensor (vetterdstr)
thanks...! that's what I read more than once....was about to install the power duct last night and the instructions stated that if you have a recalibrated MAT sensor, drill a 3/8 hole, but if you have a factory one, drill a "larger hole".... I have a factory one still and I didn't want to drill a larger hole and then upgrade to something that required a smaller hole :confused: smaller to larger works, but not the other way around......- especially if I wasn't sure about the thing .......and I'm glad I didn't install it, because it doesn't work as you stated. .......
:cheers:
Old Feb 27, 2002 | 12:42 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I did the recalibrated/relocated MAT sensor as one of my first mods. I had a new Halltec TRIC installed along with headers and some other thins at Tony's Corvette Shop since then. Tony's resinstalled the after market MAT sensor.
I have since had Heads/cam and numerous other mods done by CARTEK along with the custom tuning that they provide. Cartek did not ask to unisnstall MAT or suggest that i do so.
If i hurt these places would have had me get rid of it. Maybe it helps my car. maybe not. I am sure it does not hurt it though.
Chuck
Old Feb 27, 2002 | 01:15 AM
vetterdstr's Avatar
vetterdstr
Default Re: Recalibrated MAT sensor (chucschramm)
The way I found out it was hurting my timing and AF ratio's was to run an ease program on it and try it with the unit on and then test it again with it off. Off was better. :) We also found out that day that the Granatelli MAF was screwing my car out of runnig correctly too. That was promptly taken off of the car also.
vetterdstr :cheers:
[Modified by vetterdstr, 9:16 PM 2/26/2002]
To Recalibrated MAT sensor
