ABS flush?
Old Nov 10, 2009 | 09:38 AM
rcknusa's Avatar
rcknusa
Default ABS flush?
I tried a technique I read about to help clear the codes for service abs without sending the unit to ABSFixer. Nothing against them I just wanted to try. Now I may have gotten into a spot since I disconnected the brake lines to the EBCM. Do I need to flush the brakes or do I have to take the car to the dealer now to have them flush the ABS system?
Old Nov 10, 2009 | 09:56 AM
LoneStarFRC's Avatar
LoneStarFRC
There is a specific bleed procedure called "Auto Bleed" and it's for bleeding the ABS system. Unfortunately you need a Tech II scan tool to do it.
If I were you, I would take it to the dealer.
HTH
Old Nov 10, 2009 | 01:03 PM
rcknusa's Avatar
rcknusa
I was hoping to avoid that.
To ABS flush?
