Vortex Rammer -- Filter Maint. -- Need Tips
Old Nov 10, 2009 | 10:44 PM
wcdaniel's Avatar
wcdaniel
Default Vortex Rammer -- Filter Maint. -- Need Tips
I have a '03 QuickSilver 50th that came with the Vortex Rammer (clear box) and a Hall-Tech plenum.
Questions:
1. How often do I need to clean the filter?
2. How often do I need to replace the filter?
3. What is the best way to take the thing apart for maintenance?
4. What are the "gotchas" I need to be aware of?
Keep in mind, your audience has the dexterity of a concrete block..
Well, not quite that bad. But simple minds need simple instructions.
Remember, Confuscious say:
Fox in the hay is preferable to dog in the hay.
:o
Old Nov 11, 2009 | 01:15 PM
2KFRC5's Avatar
2KFRC5
1. Every 10k miles http://breathlessperformance.com/products/227-97.asp
I clean mine every other oil/filter change.
2. Unless it's damaged, should last a lifetime.
3. Loosen the band that holds the filter from underneath the hood, reach underneath car to remove.
4. Not not over oil. After re-oiling, let set overnight to help drain any excess oil, then reinstall.
Old Nov 11, 2009 | 04:06 PM
98vettedave's Avatar
98vettedave
Questions:
:o
I have the same Vortex Rammer as you. Each spring I disassemble everything forward of the throttle body (not hard to do) and clean each component. For the filter I use the K&N filter care service kit (lightly oiled filter) let dry before reinstalling.. For the mass air flow sensor I use CRC sensor cleaner. Everything else can be cleaned with warm soap and water.
Old Nov 11, 2009 | 08:09 PM
wcdaniel's Avatar
wcdaniel
I can safely say the responses I receive to my questions are FANTASTIC !!!!
There is nothing more helpful than real world 'EXPERIENCE'.
You guys are great.
Thanks.
Bill
To Vortex Rammer -- Filter Maint. -- Need Tips
