How Could This NOT Leak??
Old Nov 12, 2009 | 06:08 PM
soggysailor's Avatar
soggysailor
Default How Could This NOT Leak??
Doing a water pump change. I recently noticed a water leak coming from under the pulley on the water pump ,but not from the gaskets. I've had this 19997 C5 for 4 years. Looks like the pump has been replaced at least once as the gaskets are the new style, not the paper ones the 97's came with.
If you look close is looks like there's some RTV sealant on there too
These are the new gaskets I'm using with a new pump. I'm curious what would cause the deformation of the old gaskets?? Over tightening??
I'll be putting it back together tomorrow
Old Nov 12, 2009 | 06:24 PM
Cybermind's Avatar
Cybermind
Looks like some pretty bad workmanship on previous install. Was it dealer installed?
Old Nov 12, 2009 | 06:30 PM
soggysailor
I have no idea. I'm at 174,000 miles, so it's seen some work along the way.
Old Nov 12, 2009 | 06:45 PM
zeevette's Avatar
zeevette
I'm kind of interested in why you need to use RTV with the o-ring type gaskets. I've done this a couple of times and alway used extra sealant.
Old Nov 12, 2009 | 07:45 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
sweet, way to enjooy the car , I am only at 72 K but ready to pile on the miles.
Old Nov 12, 2009 | 08:15 PM
LoneStarFRC's Avatar
LoneStarFRC
There IS no "need".
Why? See above.
Old Nov 12, 2009 | 10:21 PM
soggysailor
does anyone have an idea how the gaskets got so deformed?
Old Nov 12, 2009 | 10:43 PM
LoneStarFRC
Maybe the "sealant" (what ever it was) was not compatible with the elastomer type material in the o-rings causing a softening or breakdown, or maybe there was so much applied that when tightened it somehow interfered with the ability of the of the o-ring to stay bonded to the aluminum carrier, i.e. too much uncompressible material (somethings gotta give) and lastly maybe overtorquing had a role. I would suspect probably a combination of one or more of these things. In any event, just be sure to not use ANY sealant of any kind and that the sealing surfaces are clean, undamaged, dry and NOT over torqued and you should be good to go. When I did mine a few years ago, I noticed the early signs of some corrosion on the WP mounting bolts (probably a little electrolysis going on) so I cleaned, and wire-brushed the threads, etc and applied a thin coat of anti-seize compound to the entire length of the bolts. A little preventative medicine so-to-speak and stop future corrosion.
HTH
Old Nov 12, 2009 | 10:58 PM
soggysailor
Thanks LoneStar...........good info
To How Could This NOT Leak??
