Having my ECBM repaired and figured it was a good time to clean the ground connectors out. After about a half hour attempting to dissasemble the connector I have given up for fear that I mgiht cause serious damage and then really be screwed. What is the recommend procedure for disassembling these connectors?
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
If I remember correctly the release is on the bottom and I had to remove the nut to get access. Been awhile but it solved many of my problems. Once you unbolt it you can see how it comes apart. I also recommend a shot penetrating oil so you don't bust the stud off.
I didn't have any issues getting it off the stud my problem was disassembling the connector itself. It was really difficult to separate the connector. I see how it should come apart and next to jamming a small flat head screwdriver into the sides of the connector and banging it up pretty bad I got know where.
I just didn't want to damage the wiring or connection, how hard should I be pulling to separate the connector?
