Why Does my parking brake not work
Old Feb 27, 2002 | 02:43 PM
MaddMagRII's Avatar
MaddMagRII
Default Why Does my parking brake not work
For some reason, my parking brake really sucks. I figured after i changed the pads, 2 days ago that it would hopefully get better. Does the dealer need to adjust it, I know putting the brake on and backing up supposedly adjusts (so ive heard) but still nothing. Someone please help me out.
Old Feb 27, 2002 | 03:29 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Why Does my parking brake not work (MaddMagRII)
Lots of complaints about this one, you are not alone! I have never tried it to see, if it will hold hill. Sounds like another little anoying thing like the moving seat.
Old Feb 27, 2002 | 03:57 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: Why Does my parking brake not work (wallstAL)
Lots of posts on this. The dealer should know how to make the adjustment. Then again, many have complained that the dealer wasn't able to figure it But!!! There is definitely an adjustment though 'cause I've seen posts on it.
Old Feb 27, 2002 | 04:03 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
It seems the E brake on the C5 is a problem for many of us. Mine would not hold he car when pointing downhill. I had it adjusted and it seems to work much better.
I believe the dealers either are not familiar with how to adjust the e brake or act dumb because it requires a bit of work to accomplish.
The e brake shoes are located inside a drum that is behind the rotors. This requires that all be removed up to and including the rotors. There is a star adjustment that needs to be manipulated.
I had mine adjusted out until the drum would barely fit back on.
Hope this helps
Chuck
Old Feb 27, 2002 | 04:50 PM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
The parking brake would not hold my C5 coupe on level ground with the A4 transmission shifted into gear. It took two trips to the dealer to have the brake repaired properly under the new car warranty.
There have been numerous posts regarding the poor quality of the C5 parking brake. It is another one of the car's "weak spots".
Old Feb 27, 2002 | 05:08 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
In addition to what everyone else has told you... Even after adjustment of the brake shoes located inside the rear rotors. The brakes will slowly go out of adjustment again... it might take 5,000 miles to do it... but believe me it will do it over and over again. :yesnod:
the good news is that we know how to fix it. :blueangel:
vetterdstr :cheers:
Old Feb 27, 2002 | 05:15 PM
C5GARY's Avatar
C5GARY
Default Re: Why Does my parking brake not work (vetterdstr)
And to add the last insult to this thread is:
EVEN THOUGH YOU ARE STILL UNDER WARANTEE, YOU HAVE TO PAY!!!
Chevrolet says its a normal wear item...
Even though the shop manual says its supposed to be "self adjusting".
It cost me $90.
Old Feb 27, 2002 | 05:53 PM
C54TIM's Avatar
C54TIM
Default Re: Why Does my parking brake not work (C5GARY)
It cost me $90.
That sucks!
Lil Red's Avatar
Lil Red
I would suggest that you try to do the manual adjustment at each wheel. If you can jack the car up just a few inches or so it shouldn't be too hard to do. Mine is starting to get loose and I might do it in the next week or so myself. I prefer my e-brake to engage with only 3-5 clicks. Any higher than that and you have a hard time opening the center console storage area.
Old Feb 28, 2002 | 02:18 AM
RCswish's Avatar
RCswish
Default Re: Why Does my parking brake not work (Lil Red)
Just had an episode w/the dealer....&^#^&#^%*&%*&^*$%^#@F!&%&*%*(# @^%^$&...is all I have to say...I hate those guys :mad
Old Mar 1, 2002 | 10:50 AM
C5Steve's Avatar
C5Steve
Default Re: Why Does my parking brake not work (RCswish)
If you crank the handle hard and high it will work. Non wimp e-brakes on C5s.
To Why Does my parking brake not work
