Rearend Leak....Need Help!
Old Nov 17, 2009 | 11:56 PM
customizer's Avatar
customizer
Default Rearend Leak....Need Help!
I have a 2000 corvette with 14,000 miles and it has a small leak on left hand (Driver Side) side of the rearend. I jacked it up and seen it was coming from up top. I don't know if the large o-ring on the cover is leaking or if anyone ever heard of fliud coming out of the vent tube? Thanks!
Old Nov 18, 2009 | 12:57 AM
customizer's Avatar
customizer
ttt
Old Nov 18, 2009 | 06:57 AM
utownal's Avatar
utownal
My 2002 coupe started leaking in the same area with only 5,000 miles. There was a recall
to replace a seal which I learned about from this forum. I took it in and got it repaired. The
car was about 3 yrs. old at the time. I think this is a common problem with C-5's.
Old Nov 18, 2009 | 07:30 AM
65GGvert's Avatar
65GGvert
The search button can be your great friend.
Old Nov 19, 2009 | 11:33 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Default To answer your question YES!
I had my 99 serviced for the leak in the side cover and the axle shaft. When they refilled the rear end they over filled it and yes it will come out the top!!!!!!! I was afraid it was leaking again. I put it on my lift at home and when i pulled the plug gear dope greeted me. I cleaned everything up and let the excess drain out and have not had any more signs of fluid.
Old Nov 19, 2009 | 06:35 PM
Swt_86's Avatar
Swt_86
Before you jump in and change the seal, check the vent at the top left of the rear end. Thought my seal was leaking, cleaned the vent and haven't had a problem since.
Old Nov 19, 2009 | 09:48 PM
Steve D.'s Avatar
Steve D.
Default Rear end leak
My 03 Z06 was leaking from the vent. I thought it was a seal at first.
I drained the fluid and replaced it with Redline making sure I did not over fill the case. No more leaks.
Old Nov 20, 2009 | 12:10 AM
sperkins's Avatar
sperkins
I made a temporary fix to my leaky rear with "The Right Stuff Gasket Maker".
It worked so well that I made it my permanent repair. Took about 2 minutes.
Old Nov 20, 2009 | 12:54 PM
NatB's Avatar
NatB
What exactly did you use the stuff on- not the axle seal for sure? Maybe the case?
Old Nov 20, 2009 | 01:56 PM
sperkins's Avatar
sperkins
No not the axle seal. Mine was leaking where the tranny and diff connect. A little dab'll do ya.
Old Nov 22, 2009 | 10:03 PM
customizer's Avatar
customizer
Mine is spraying at the top on the under side on the car left hand side so I got my hand up by the vent and wiped everything clean. Haven't drove it yet raining outside but will see what happens...Thanks!
To Rearend Leak....Need Help!
