Telescopic steering help needed
Old Nov 18, 2009 | 02:25 PM
Mr. Jean's Avatar
Mr. Jean
Default Telescopic steering help needed
Did a search and found nothing, so here I am. It stopped moving into positions of memory and I've tried the col. button/**** and I've ran a codes test. No NEW codes, just 2 history codes.
B2860H which is a sensor failure code for it and U1160H.
Where is this sensor located? It shows as an H (history) but you never know.
I've checked the manual and can't find a fuse location for it. Is there a fuse and if so, where is it located?
It's a 2001 A4 Coupe. Anyone have any suggestions?
Thanks for any and all help.
Old Nov 18, 2009 | 06:34 PM
Johnny Hardcore's Avatar
Johnny Hardcore
I can't tell if you tried the following...
Turn key to "on position" without starting the car.
Push the column button in 6 times and then hold it in for a few seconds.
Then push the column button backwards 6 times.
Believe it or not this works. The "soft stops" may need to be reset.
I was a non believer and I had tried this in the past and didnt get it to work. Then today when I was leaving a client visit I said whet the hell and tried it again...and low and behold...it worked.
Telsecope is back in action. I drove the car for a whole year with it semi retracted. Now its fixed.
Sorry to all those that I doubted in the past!
Try the above fix , maybe its not the relay. Good luck!
Old Nov 18, 2009 | 07:16 PM
Mr. Jean's Avatar
Mr. Jean
Now that you say that, I do remember hearing that before.
I had just forgotten about it. I'll go give it a try. Thanks.
Update: Yup, that fixed it all. What a relief, that I don't have to go see the Stealership with it.
Thank you Johnny. I really love this place and the sharing of information and ideas. Thanks again.
Old Nov 18, 2009 | 08:17 PM
Johnny Hardcore
Great news Mr. Jean...now go spend the money you saved on new performance mods!
To Telescopic steering help needed
