wheel bearings
Old Nov 20, 2009 | 09:24 PM
cobra3's Avatar
cobra3
Default wheel bearings
I have a little noise from the rear end but does not change when rocking the vech side to side . I put the vech. in the air and checked the rear wheels for side to side play and have just a touch of play in the right rear. I guess I will change both bearings while I am there . My question is do I need anything special as far as tools to get the knuckle off , dont want to hit it with a hammer so whats the easiest way to get it apart. Should I use GM bearings or another brand , any help would be great and thanks in advance.
Richard
Old Nov 21, 2009 | 07:06 AM
k24556's Avatar
k24556
This link should tell you everything you need to know about replacing the outer rear bearing. When mine went bad, I would get a louder whine on the side that had more force on it. So, a left curve in the road would make the right side noisier
Heres the link: http://www.docstoc.com/docs/15125940...ng-Replacement
It was an easy job, hard on the knuckles so wear gloves! Also you will be sitting indian style most of the time. The person that wrote this did a great job.
Old Nov 22, 2009 | 06:33 PM
cobra3's Avatar
cobra3
the link is for the front and I need to replace the rear bearings , thanks anyway
Old Nov 23, 2009 | 07:42 PM
k24556's Avatar
k24556
Sorry about that. Try this link:
http://www.jakelatham.com/C5/misc/
he did two writeups and they look the same. This should help
To wheel bearings
