Oil change message won't reset
Old Nov 24, 2009 | 01:37 AM
bud258's Avatar
bud258
Default Oil change message won't reset
I have tried what the manual says for a week now and the message keeps coming back.It resets to _ _ _ % but wont go to 99% like the book says it should.I didn't reset it with the last oil change and it only has about 1500 miles on that change so I know its not due yet.Can somebody help me out since I appear to be slightly ignorant about this issue.Thanks
Old Nov 24, 2009 | 01:43 AM
C5XTASY's Avatar
C5XTASY
The oil change indicator has not been reset. Do this....with the engine OFF, turn the key to the RUN position (not START). Floor the gas pedal three times. That will reset the oil change indicator to 100%. When you drive the car for a short distance the indicator will drop to 99% and function normally thereafter.
Ed
Old Nov 24, 2009 | 01:47 AM
bud258's Avatar
bud258
Thanks I'll try that in the morning...I knew someone on here would know how to fix her.
Old Nov 24, 2009 | 06:32 AM
Rat Fink's Avatar
Rat Fink
With the key in the on engine off position push down 3 times on the gas pedal this will reset your oil life
Old Nov 24, 2009 | 11:03 AM
bud258's Avatar
bud258
Gas pedal method seems to have fixed the problem.I tried the way the manual says again just to be sure first and it wouldn't reset.Thanks for the info folks I appreciate it.
Old Nov 24, 2009 | 12:38 PM
C5XTASY's Avatar
C5XTASY
Old Nov 24, 2009 | 02:24 PM
rboineau's Avatar
rboineau
Default oil change message reset
A lot of people--myself included--tried to reset with the engine running. As the forum member posted above, engine has to be off.
Old Nov 24, 2009 | 02:27 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Thanks for this post! I was wondering why mine wouldn't reset and I've done it many times before.
Old Oct 17, 2024 | 11:41 AM
Ruthensford's Avatar
Ruthensford
3rd Gear
I have a red 04 C5 as well and I’m experiencing this same behavior. Car on engine off, both gas petal method and trip/reset button method doesn’t work and it’s been weeks. I also disconnected the battery and waited a hour to reconnect and it still won’t stay reset.
Old Oct 17, 2024 | 11:55 AM
lucky131969's Avatar
lucky131969
Congrats on reviving a 15 year old thread. To confirm, you are doing the following? :
GM Oil Life System - Resetting
Resetting Procedure
Follow this procedure to reset the GM Oil Life System ™:
  1. Turn the ignition to ON with the engine off.
  2. Press the TRIP button so the OIL LIFE percentage is displayed.
  3. Press the RESET and hold for two seconds. OIL LIFE REMAIN percent will appear.
The DIC buttons get a little finicky after 20 years. They may require a little more gentle pressure.
Old Oct 17, 2024 | 12:30 PM
Ruthensford
3rd Gear
Yes i have completed these exact steps. I hear the little sound and see the oil life go from 47% to___% then to 100% when holding the reset button while viewing the oil life on the display. Also hitting the gas 3 times resets it successfully as well but it won’t stay reset and goes back to 47% anytime i jump back in the car. I’ve also driven it immediately after resetting it as well but no luck.
Old Oct 17, 2024 | 02:33 PM
lucky131969
Strange that the PCM will not reset. Any codes?
Old Oct 17, 2024 | 04:55 PM
Ruthensford
3rd Gear
Nahh no codes at all. Also i think it’s even more strange that when it goes back to 47% it stays there, it doesn’t decrease at all. I’ve driven over 2k mikes for sure.
To Oil change message won't reset
