What is the right cam?
Old Nov 24, 2009 | 07:14 PM
ethamer1982's Avatar
ethamer1982
Default What is the right cam?
Guys, I do have a 2001 C5 Coupe, 4-Speed Auto Transmission
I am looking to install a new performance camshaft. I am looking for the following with an expert recommendations :
1. Extreme power
2. Wild sound
3. Running idle rpm not more than 850 rpm
I got installed the following in my vette:
ARH 1 7/8 long tube headers with 3"X3" X-Pipe (off-road)
B&B Cat back 4" quad tips
Vararam intake
Bosch 42 lb Fuel injectors
Custom tune (HP Tuner)
I don't want to do any fly cut, and I am considering AFR heads later on (No enough budget )
So, any recommended package, or cam, or even any custom cam that would meet my expectations. I have seen some vette's having a custom cam having an LSA of 117 and high lift up to 0.610/0.600 and gained about 70 RWHP
I know there are a lot to gain from your experiences guys, just guide me. The cam choice is the pending issue that hold the completion of my project
Wish me luck!
Old Nov 25, 2009 | 06:05 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Contact Englandgreen, they will hook you up ! (supporting vendor on this site) Necessary Evil!
Old Nov 25, 2009 | 04:09 PM
99 vett babycar's Avatar
99 vett babycar
why are you running 42 lb injectors ?
Old Nov 25, 2009 | 05:56 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I have a MS3 in mine its a 237/242 with a .609 lift it has everything you asked for but it idles around 900-1000rpms, and has a very mean lope to it.
Old Nov 25, 2009 | 09:59 PM
redC5_4wife's Avatar
redC5_4wife
Navigator
Default same question here
Lucky for me, my 04, A4, came w/AFR 205's on it. Haven't checked to see what springs might be on them but at the most they will handle an MS3 with the standard springs from AFR. I don't want that much chop at idle. Also has Vararam, 01 Z06 MAF, and 3.73's.
Old Nov 27, 2009 | 09:44 AM
JPEAK's Avatar
JPEAK
Why are you running 1 7/8 long tube headers?
Old Nov 27, 2009 | 10:23 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
unless the person has tuned and installed a few dozen cams, don't listen to them
contact your local
or find a reputable tuner in your area and go from there
To What is the right cam?
