Will these tires fit?
Old Nov 27, 2009 | 05:43 PM
chrisbenoit's Avatar
chrisbenoit
Default Will these tires fit?
I am buying a set of C6 wheels, so they will be 18x8.5 and 19x10's. Will 255/35ZR18 fit on the front and a 305/30ZR19 fit on the rear? I want jam in the most tire I can but I don't want it to rub. If these won't work, what will? My car is a 99FRC. thanks.
Old Nov 27, 2009 | 05:57 PM
chuffo302stang's Avatar
chuffo302stang
it would probably be better to run a 255 or 245 40 18 up front
since your wheel is only 8.5 wide
http://www.1010tires.com/tiresizecalculator.asp
This web site is helpful, its similar to a chart I had when I was in the tire business
Old Nov 27, 2009 | 09:36 PM
3whit's Avatar
3whit
I run stock C6 Polished wheels on ,my C5 but the sizes I used were the stock C6 sizes 245-40-18 and 285-35-19 ,you will need a spacer on the rears fronts will be fine .
Old Nov 28, 2009 | 06:32 AM
chrisbenoit
Would a 245/40/18 and a 305/30/19 set off any unwanted TC or active handling codes? The fronts are the same overall height as the stock C5 tires while the rears are slightly smaller. Going from a 26.6" to a 26.25" inches. It's only about 1.5% shorter. I work for Michelin so these are the Pilot Sport PS2 numbers, the tires are free so I want to go as big as possible.
Old Nov 28, 2009 | 09:38 AM
chrisbenoit
They do make a 255/35/18, they would be 25.0" tall verses 25.7" tall. That is approximately 2.8% shorter than stock. Will a 255/35 at 2.8% shorter and a 305/30 that is 1.2% shorter trigger any codes in the car?
Old Nov 28, 2009 | 06:52 PM
chrisbenoit
bump
Old Nov 29, 2009 | 01:55 PM
chrisbenoit
I trust 8VETTE7, he helped me on numerous occasions but just looking for another opinion, Will a 255/35/18 at 2.8% shorter and a 305/30/19 that is 1.2% shorter trigger any codes in the car? TC or active handling, I'm not too concerned with the speedo being off, I'll be happy if that is all that is affected.
Old Nov 30, 2009 | 12:21 AM
rebelheart's Avatar
rebelheart
I run 305/30-19's on mine with C6Z06 wheels and stock C5 offsets.They barely touched the innner panels under "spirited" driving conditions.A 1/4 inch spacer cured that.
Old Nov 30, 2009 | 02:00 PM
slverbulletz06's Avatar
slverbulletz06
I Ran 335/40/18 On My zo6 and i had no rubbing issues, it is a 10.5 rim
Old Nov 30, 2009 | 03:35 PM
chrisbenoit
8VETTE7, what do you mean by "delta"? this may be a stupid question, Is a 255/35-18 and 305/30-19 acceptable? Thanks.
To Will these tires fit?
