How to pull engine... top or bottom?
Old Dec 6, 2009 | 11:49 AM
calvette 11's Avatar
calvette 11
Default transmission
Originally Posted by ragtopws6
If you don't have a lift, I would say coming out of the top would be easier, unless you need to drop the rest of the drivetrain.
If I left the transmission in,how hard is it to put the engine in.My car is a six speed.I'm worried about the clutch and transmision lining up
Old Dec 7, 2009 | 08:09 AM
calvette 11
What if you have a 6 speed,can the drive be left in
Old Dec 8, 2009 | 12:13 AM
Roger Z06's Avatar
Roger Z06
The Tranny is in the rear so if anything you would have to worry about the Torque Tube which I think does not get in the way of pulling the engine out from the top, putting it in should be just as easy if not easier than lining up the heavy torque tube and tranny with a jack.
Old Dec 8, 2009 | 12:21 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would imagine the only issue on taking it out from the top is moving the steering rack out of the way, condensor and so on. Then supporting the torque-tube so that the engine can be slid forward off the shaft, enough to clear everything in front. Then up and away. I've not done it, but shouldn't be too hard.
Old Dec 8, 2009 | 01:59 PM
Tech's Avatar
Tech
I'd fix the 2 post lift, myself.
Old Dec 9, 2009 | 10:55 AM
calvette 11
Default engine
Let me explain maybe I just too old school.The shaft that goes into the pilot bearing,has to line up with cluch disc and go though the pressure plate.On my other cars this is not easy,with the transmission in place.How can it be done with a mounted five hundred pound drive shaft in place.I want to try it,but I don't like failing and can't complete a job I start.I want to put a 402 in this winter
Old Dec 9, 2009 | 11:07 AM
Tech's Avatar
Tech
Lots of patience and minor adjustments with jacks. Some swearing and beer helps.
Old Dec 9, 2009 | 11:30 AM
nickolbag's Avatar
nickolbag
Easy. Lining things up isn't a problem.
Dont have to touch anything from the TT back.
I removed the rack when I pulled the motor. I'm pretty sure it will hit. I dropped the rack completely off the bolts unlike Cajundude. I could not get the oil pan to clear the cradle on the bolts. Dropped it about 2" off the bolts and it slid right out. The condensor does not get in the way.
Just line up the clutch and it shouldn't be that hard to get it all together. It took me and a friend a little bit to get it to go together making small adjustments at a time.
Old Dec 9, 2009 | 03:28 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Getting it back together is all about finesse, so put your sledge hammer down and work it in there. Make sure when you set your clutch and pressure plate that your alignment tool pops in and out easily. If it doesn't, re-set it. If you have trouble in the middle of it, PM me and I'll give you my phone # and then I'll try and talk you through it. My motor hoist tool is something I rigged up and I can change and hold the angle of the engine with it. It takes some manipulation, but I always get it in there.
Old Dec 9, 2009 | 04:29 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
ive done both. Both have its ups and downs. If you dont have a lift, I sure wouldnt trust jack stands.
Pulling from top is ok, but you need to remove the bumper, most cherry pickers are not big or long enough to do it with the bumper on, and when I pulled mine, it still wasnt long enough to lift straight out, i needed 3 guys to push the engine as i was cranking it up, and putting it back in was a bitch, I absolutley hate lining up the TQ to the motor. I actually cracked the bellhousing puting mine in. had to weld it up.
I have put a 440 in a Z06 by lifting the car up. the only pisser is all the wireing, but def alot easier, and can be done by 1 guy. i think this was my fav way because you didnt haev to unhook the drivetrain, and if you did, you can jsut use a tranny jack to slide the motor back onto the torque tube, instead of laying on the ground fighting those bolts and alignment
Old Dec 9, 2009 | 05:08 PM
nickolbag's Avatar
nickolbag
My engine lift was to short too. All I did was lower the cradle more and it allowed me to slide the motor foward without it lifting up. Still only a 1 man job. To put the motor back in I went in from the side like the pictures posted in this thread. No need to mess with the bumper. Took 2 of us to get the enigne and TT lined up. Definitly wouldn't want to try that by myself.
Old Dec 9, 2009 | 05:29 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Bottom dropper myself w/ lift.
this thread would be a bit smaller if you yanked out the keyboard wrenches
shop manual is going to help you? not on this task
Old Dec 9, 2009 | 08:07 PM
  #33
VGLNTE1's Avatar
VGLNTE1
I thought of going from the side, but i was in fear for my newly painted fender:o
Old Dec 11, 2009 | 01:36 AM
  #34
Roger Z06's Avatar
Roger Z06
I have lined up the TT into the engine numerous times with no problems. I think it is actually harder to hit it perfectly to where it stops than it is to catch it just enough to spin your clutch/TT input shaft. A few times I did it by myself I pulled the heads off yesterday(making sure it wasnt a headgasket) and am pulling it out today/friday
