disconnected battery
Old Dec 2, 2009 | 06:54 AM
buckster's Avatar
buckster
Default disconnected battery
I read on here that if your battery has been disconnected for awhile you may need to do an idle re-learn process. My question is if you don't have an OEM tune and have a Diablo Predator Tune is this still necessary?
Old Dec 4, 2009 | 01:38 PM
RyanR0101's Avatar
RyanR0101
I don't find it necessary even with a stock tune. I put my battery back in every spring coming out of storage and have had no problems.
Old Dec 4, 2009 | 03:34 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The only things that you lose with disconnecting the battery is all the weather related tuning parameters that have been learned out--The ECM basically starts from sqaure 1 and goes thru a re-learn process--It should only take about 50 mile or so for them to learn out again-Weather related things are like atmospheric pressure--altitude-outside temp or air density ---The other times it will idle badly or hunt for an idle speed is if your T-body had learned out when it was clean and now it is carboned up some and you re-set the fuel trims or did an idle relearn or disconnected the battery after it has become carboned up and originally it had learned out when it was clean--
Old Dec 4, 2009 | 03:54 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
If you want to do one here ya go
http://www.c5forum.com/diy/idlerelearn.php
Old Dec 5, 2009 | 10:40 PM
buckster's Avatar
buckster
To disconnected battery
