243 Heads with special markings?
Old Dec 2, 2009 | 07:50 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Default 243 Heads with special markings?
what is the special markings I read somewhere that the better 243 heads have? they are suppose to flow better?
I figured someone in the tech section would know
Old Dec 2, 2009 | 08:49 AM
cenman's Avatar
cenman
The better ones have triangle markings on the edges.
Old Dec 2, 2009 | 10:35 AM
printmanjackson
ok, I found this link that shows what they look like.
http://www.carcraft.com/techarticles...ads/index.html
Old Dec 2, 2009 | 10:47 AM
cenman's Avatar
cenman
The triangle markings should be under each spark plug hole.
Old Dec 2, 2009 | 08:47 PM
printmanjackson
so these triangle heads are suppose to have more hp and I take it from having better flow. Would that be on the intake runner side?
Old Dec 2, 2009 | 11:08 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
These are casting marks indicative of the heads that were made using the semi permanent mold casting process. The marks are not special, I have two sets of 241 casting heads in my garage that have the triangle casting marks under the spark plug areas.
To 243 Heads with special markings?
