What makes the difference in brightness.....
Old Dec 2, 2009 | 11:36 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default What makes the difference in brightness.....
if both bulbs are rated the same wattage?
Example:
The sylvania OEM bulb is rated 55 watts.
The sylvania silver star ultra bulb is rated 55 watts.
What makes the SSU bulb brighter?
Old Dec 3, 2009 | 10:12 AM
Vettedriver986's Avatar
Vettedriver986
Its really not all that much brighter. Just a different color sort of. Best bet if you want brighter is to convert to HID. Go with 6000k, and you will be happy. I have 6000k on my Z06 and I love it.
Old Dec 4, 2009 | 02:40 AM
ZeeOSix's Avatar
ZeeOSix
The hotter the bulb filament glows, the whiter the light becomes. 55W at 6000 deg K is whiter than 55W at 5000 deg K for instance.
Also, typically the hotter the filament glows, the shorter the life of the filament.
Old Dec 4, 2009 | 07:09 AM
Cybermind's Avatar
Cybermind
I agree. Everytime I switched to these so-called "super white" bulbs, they would burn out in less than 6-months. I always ended up going back to standard bulbs. Just not worth it. Also since they burn hotter, they are more sensitive to the amount of on-off cycles which will also shorten their life.
Old Dec 4, 2009 | 09:47 AM
cdnguyred88's Avatar
cdnguyred88
Went from stock to PIAA bulbs now running HID, what a huge difference.
To What makes the difference in brightness.....
