If a non run flat loses all air and is setting on the bead and will not seal, is there a very small jack available to carry on board to raise the car high enough to get the wheel off the bead! :smash: :seeya
Re: very small jack available to keep on board (EMDExpress)
This is a good Idea. I hope it works when the time comes... when I had a flat tire on my non run flat both beads were off the rim by about 1.5 inches. There was no way I was going to even get a jack under the lowered car. I will tell you that the rim was suspended in the air and didnt even touch the ground though. :eek: I was happy about that. There was no damage to the tire... just took it to a tire shop on a flat bed and they took off the rim and (had a Heck of a time reseating the bead) ballanced it, then reinstalled the T&W.
Re: very small jack available to keep on board (vetterdstr)
Wonder what it would take to put the 4 hydrolic lifts like they have on the f1 cars.. It would add some weight, but it sure would make oil changes easy...
Re: very small jack available to keep on board (ICULUKN-C5)
If you are running non run flats, can tell you this is a real problemo...by experience. With that tire flat on the ground, there is no way to get a even a floor jack under there. So doesn't matter how many flat fixer kits you have. Can tell you that a Lexus jack fits :D ... but sure siccisor Honda jack would be better price wise. :yesnod:
Re: very small jack available to keep on board (DUKE)
I remember seeing an inflatable bladder type jack on a web site a couple of years ago. As near as I can remember it was pretty thin in the collapsed state. I wasn't very impressed with what I saw on the web. The scissor jack sounds the best too me.....but would like to know the amount of clearance required when non run flat is totally flat.
