AIR system and o2 not hooked up
P0410 AIR System
C1276 Delivered Torque Signal CKT Malfunction
U1255 Serial Data Line Malfunction
when I put new headers on it only had one AIR hookup on the passanger side so the drivers side I just tore off the metal piece and plugged the vaccuum line - when I put the stock headers back on I just plugged the hole - now Im getting the p0410 CEL- is this most likely the problem?
Also when I did the header install I never hooked up the secondary o2 - could that be related to C1276?
