Z06 Injectors
Old Dec 4, 2009 | 12:51 AM
sbadd99's Avatar
sbadd99
Default Z06 Injectors
guys I just brought a set of used injectors, my parts CD only covers 99-02 and I need to double check that they are 28.8lb Z06 injectors, if anyone can look up the part number for me i would appreciate it.
# 12555894
cheers
Kim
Old Dec 4, 2009 | 06:35 PM
das 02 vette's Avatar
das 02 vette
Cruising
I just bought one actually.. The numbers on package are as follows (ACDELCO part) ACD#217-1528 GM#12482704
I hope that helps you
Old Dec 4, 2009 | 10:37 PM
sbadd99's Avatar
sbadd99
thanks but no it dosn't, I dont have a package just the injectors one side is stamped # 12555894 the other side 0280155890
Old Dec 5, 2009 | 10:50 AM
das 02 vette
Cruising
the old injector that i pulled out has the numbers 0280155931 on one side and 12561462 on the other. not the same as your but very close. Im no expert on if the markings varied much. Mine came out of my 02 zo6...I dont think that should make a difference as long as its an ls6, im just giving you all possible info.
Also on the injector where it clips to the harness there is a big C and underneath it there is 927 and in white on the center is 216641. that all the numbers i got man hope it helps you.
Old Dec 5, 2009 | 10:25 PM
sbadd99's Avatar
sbadd99
Das, I have E then 972 no other numbers, will keep checking, dont want to go to the trouble of installing if they are wrong, thanks
Old Dec 5, 2009 | 10:41 PM
sbadd99's Avatar
sbadd99
my car just came back from the shop, they are just standard Bosch 26.6lb as fitted to 99's, damn, and I brought them from here.
Old Dec 5, 2009 | 11:31 PM
sbadd99's Avatar
sbadd99
guy I brought them from has bent over backward to make it right, is actually removing the injectors for his own car and sending them out, only problem is then he is a bit stuck, ya gotta love the guys on this forum,
Kim
To Z06 Injectors
