TPMS Calibration?
Old Dec 5, 2009 | 04:21 AM
Choreo's Avatar
Choreo
Default TPMS Calibration?
Temperature just dropped today from 70-degrees to 32-degrees. My tires are only a month old. The front tires went from 30psi to 28psi (typical) with rapid temp drop, but the rear tires went from 30psi to 24psi on the DIC (both sides)??? I got the low tire pressure warning on the DIC. I checked with two pressure gauges and the back tires both showed 27.5psi on both gauges. So I aired them up to 32psi, but all day long the DIC never showed above 30psi.
What would cause the DIC to display the wrong pressure? Sensors are two years old. Rear tires were showing 30psi the past week which agreed with the hand-held gauges.
Old Dec 5, 2009 | 09:50 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Sounds like the roll swirches may not be activating causing the sensor to only transmit pressure readings once per hour instead of once per minute. This would explain them not registering the change in pressure when you added air.
Old Dec 5, 2009 | 10:31 AM
Mark C5's Avatar
Mark C5
Originally Posted by 8VETTE7
Did you drive the car after adding air? Mine have to be drive a ways after adding air to see the new pressure in the DIC. Been that way since I got the car.
They are all that way. You have to drive the car to activate the roll switches which takes the sensors out of stationary mode. In stationary mode they only transmit once per hour to save battery life. Once the wheel is rotating the roll switches are activated and the sensor transmits once per minute.
Old Dec 6, 2009 | 01:17 AM
Choreo's Avatar
Choreo
Yes, I am used to it taking a while to register updated readings. Again today driving around still 2-psi shy? The rear tires updated from 27.5 to 30, but do not show 32 as they should?
Old Dec 6, 2009 | 01:24 AM
Choreo's Avatar
Choreo
I ma not having trouble with the DIC updating - just not accurate - today shows 30 on all four tires instead of 32. Maybe both hand-held digital gauges are wrong?
Old Dec 6, 2009 | 03:05 AM
87SAM's Avatar
87SAM
My sensors read a PSI or 2 lower than my hand held gauge and they are just a couple years old. Seems like my old ones did the same. Since I know it, it all works out.
Old Dec 7, 2009 | 01:43 AM
Choreo's Avatar
Choreo
Well... what can I say? Driving around day 3 (today) the DIC finally read 32 in all four tires???
Old Dec 7, 2009 | 08:26 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Another unexplainable phenomenon!
You would think that a pressure update should occur once an hour, whether the wheel is rolling or not.
Old Dec 7, 2009 | 11:21 AM
TEXHAWK0's Avatar
TEXHAWK0
Did the ambient temperature increase?
Also, are you sure your gage is accurate?
Old Dec 7, 2009 | 10:51 PM
Choreo's Avatar
Choreo
Ambient has been pretty stable the past few days - within 5 degrees while I am out driving,
Can't swear to accuracy, but both handheld gages agree (one digital and one analog). Of course, now the DIC even agrees.
To TPMS Calibration?
