Thanks for the quick reply, read another that said to verify just turn the key to the "on" position and read the oil pressure. Should be zero but mine started at 35 and after 5 seconds said 48psi.
It's obvious that GM had a run of bad replacement sensors for some time. Since the replacements were no longer made of brass, now aluminum, a strong correlation was made by many that there is something intrinsically wrong with the aluminum(in addition to the electronics). So even though there have been a few failures posted with brass replacement sensors(nothing in comparison with the GM aluminum replacements), the standing forum recommendation is for a brass replacement/relocation. In all fairness, the replacements were absolute crap for some time. Some poor guys had them fail very soon after replacement...immediately after install, a few miles down the road, etc. The aftermarket sensors (like the Borg Warner) have proven to be more dependable......and they are made of brass.
There is no telling if GM was ever able to quarantine the lot of bad replacements......probably from lack of feedback from buyers. To the best of my knowledge, while the dealership will warranty the sensor, I don't think they will refund your money. Instead, I'm pretty sure they will just give you another sensor at no charge, but in reality, who is going to risk that? So I'm sure that most cut their losses, and purchased an aftermarket replacement, and called it a day. Problem with that scenario is, GM does not get feedback from the dealers that there is a problem with the replacement sensors, and thus, they do not investigate.
There is one thing for certain...the oil pressure sensors that came from the factory were certainly the most durable.
Is this a holiday season problem? This just happened to me yesterday Freaked me out!
So Lucky,, is there an over all favorite for the replacement out there? I need to get one asap so I can stop feeling sick about it. Guess I will check for the sticky someone mentioned as I have no idea where this is located and if I can pimp it out myself
As far as you want to without knowing what your engine oil pressure really is. Or until you hear a lot of wrapping coming from under the hood. Which ever comes first.
Brat! Happy Holidays buddy! Thanks again for your help with the CLB
